LOL, What were we debating?I rest my case...
I have to admit that I'm a lot lazier that Doc. I hate fishing for hooks with rubber bands. And having to keep a fresh supply of rubber bands. Also rubber bands just seems like a cop out for a $500 glider! Even with rubber bands I'd have needed to make a hard point to anchor the hooks. So why not do it right in the first place!
I was surprised at just how much left over epoxy there was on the back side of the wing root. This was gross and makes for an unnecessarily heavy model. To clear this bead of epoxy I had to groove the hardwood block to allow it to seat against the rib. Here I made a mistake. One should use plywood as the hard point. A solid block of wood will tend to split when drilled and tapped. (It was late at night when I added these to the wing. That's my story and I'm sticking to it)! Later I made the fuselage threaded hard points out of plywood.
The key to this retention system is the use of TopModels (Clip Fixing mini P/N03801) these include a nice separation tool (wedge). You will need a set of taps (8 x 1.25mm and 5 x 0.80mm. These are used to tap the hard points and allow for adjustments. (BTW; you can adjust the break a way force by making the retention arms longer with the use of a hacksaw).
Top Model Mini Wing Locks
The Mini Wing Lock is intended for smaller planes with thinner wing profiles; thermal gliders, slopers and the like. The Mini Locks can also be used to make wing tips that simply click into place. On some aircraft fuselages it is not practical to use inte
Now I have a simple and elegant retention system that is fast to assemble on the slope and doesn't need added parts that wear out, break or deteriorate (No rubber bands here)!
Also you can see that I have an auto plug in harness.
