Motowncali
Active User
Let me start with... This Thing is a BEAST!
The plan is to put the servos in the tail. I also would like 2” of rudder each way for beautiful hammer heads...
So, first thing that needs to be done is open up the gap slightly for the rudder. The swiper is smooth, but because of the shape and thickness, the rudder will have less effect when deflected opposite the hinge line, 1/2” of the rudder is now inside the post... carefully taped my ruler in place and removed an additional 1/8”, got a 1/2” more easy throw instead of fighting to move it... Yes, that is a 12” ruler on the rudder hinge line! Didn’t I say this thing is huge?!?
The next thing I noticed was the because of the taper of the vertical fin, the rudder was also offsetting vertically and rubbing at the top. A little careful sanding and I was able to get even freer movement. And you cant hardly tell the at the top gap is 2mm wide instead of 1mm.
