A while back I spotted an inexpensive foam glider on the Aero-Naut catalog and thought I needed to see if it is any good.I think this design has been around for a long time, but have never seen one. So I ordered in a case of them and our buddy Scott was nice enough to build it for us at one of our build nights. (Warning, come to a build night at Aloft without anything to build and we will put you to work.)
It is an easy build, mostly adding in some spars and some wood here and there. The wing is a single piece. Foam is EPS. It builds out light, 14.7 ounce AUW.
For me the appeal of this plane was low price budget sloper. So we outfit it with the finest in cheap 9 gram servos as we wanted to try this as a true budget plane. We powered it with a rather old 4 cell NiMH 1300 pack. Probably put a small 2S lipo and an old ESC to act as a BEC for future flights.. Again on the idea of keeping her cheap.. The NiMH pack is too old and tired for reliable use.
The build was straight forward and we followed the english instructions. Heck, she even comes with sandpaper in the box. We used mostly Foam Cure glue and some 15 minute epoxy for the wing mounts and the control horns. No tricks to the build. We needed a small bag of lead to make the factory suggested CG with the battery we picked.
Maiden flight went great. Wish I had some video, but she flew out and was a lot of fun to fly, she was a bit nose heavy with the CG set to the spar location, so landed and moved things around to move the CG back to the rear of the spar and she was happy here. Passed her around to several other pilots for their thoughts. While she is not extreme in any way, she doesn't seem to have any handling concerns either.
I mixed in a bit of spoileron (aileron up) to assist in landing, and this worked out well. Our local field has a small landing area, and the spoilers helped nail the landings.
I was pleasantly surprised that the rudder was very effective on this plane, more so than I expected. This made aerobatics a more fun. I didn't have a ton of throw on any of the surfaces and she was flying light on her 48" wings, but she was happy to do all of the aerobatics I asked of her. Pretty good roll rate, nice clean loops, and decent inverted. With the rudder you could get a slow snap roll out of her. She turned a respectable range of speed that ranged from nice and slow to decently quick for foam weighing this little.
She is happy to fly in a very small space if needed, I always like foam that can do that. I will be playing this more in future flights to see if I can do a series of aerobatics in a 10 foot cube on the slope. This is good fun and hard to find a plane that can do it, but think this one will work.
Not bad for a plane that costs under $70 and is easy to build. Did we mention it is German.. LOL
A quick word about EPS foam - Yeah, this is that cruddy EPS foam. It is not durable like the EPP or EPO planes you may be accustomed to, but it is not all bad. EPS is is stiffer and lighter, but it picks up dents over time. It would be a good idea to put some tape on the leading edge of the wing and bottom of the fuselage if you are landing in rocks or weeds/bushes. The good thing is EPS is very easy to repair and fill. Should you break the plane, just clean things up and glue it back together. A little epoxy or Foam Cure will get you going. Foam Cure will take all night to cure, so epoxy is best for quick fixes. Avoid CA glues as they will melt the foam. Same with most all spray paints. The foam safe CA and paint should still be tested as I have seen some of them still melt EPS foams. You can fill big dents with light weight wall filler with great results. If you want to go crazy you would fiberglass over the foam, but probably not worth the trouble.
I think the low price makes sense for this plane. She will not be a combat plane, but kept light I think you will have a very enjoyable sport slope glider that may surprise you.
We should have them up on the site soon. (Will try to get better pictures next time she is out.. Hopefully no fog then..)
