Should work with ELRS, and it is the latest firmware for all radios.Hello Mike.
Thank you very much for your work.
My 9xr-pro still in use and no want's to go out.
I have a couple of question: 223 firmware from http://www.er9x.com/ will work with r9-m on ExpressLrs, right?
Is it the latest firmware for Turnigy 9xr-pro?
Correction: "10CH", not "10" was what I selected from the listing in Options after binding.So entering βCHβ caused a memory roll over event?
Now that's a quick turnaround. Good job, MikeB.I've fixed the bug on the TX16S where the internal module didn't update with the bind data from the module when using DSM protocol.
A "test" version of erskyTx for the TX16S is here: https://openrcforums.com/forum/viewtopic.php?f=7&t=4676&p=65894#p65894
Mike
It's a binary thing in that changing a binary 8 to a larger number requiers another bit. As it looked to me as you dropped the "CH" that the bite might have been able to register correctly.Correction: "10CH", not "10" was what I selected from the listing in Options after binding.
I'm not sure what a "memory roll over event" is, but that's what enabled all 10 channels to be active.
MikeB really is the best! I fear how the Hobby will stagnate should we loose Mike.Now that's a quick turnaround. Good job, MikeB.
