Well, that took 4 hours to install the servos. Key was to make sure that the wire pushrods were a bit long so that I could use a kink to trim the surface.
Note; that I had to drill custom holes that matched the wire diameters I used (0.015" for the elevator and 0.024" for the rudder). The stock holes in the servo arm were 0.020 (0.5mm). I tried to make sure that the push rods were 90° to the servo arm running through the center of the servo output.
I also added the finger trap door in an effort to cut down on the drag this open hole would produce. It is working well, much better with a carbon leaf spring than the wire I used originally.
Now all that is left is the hard part, flight test. Right now she is setting in at 290 (305)grams. That's a loss of over 3 oz (90 grams)! I'm sure I'll have to add some more weight as it looking like she is rigged a bit tail heavy, even for me!
