Hey Doc,
Not having really been in this glider forum until fairly recent, I thought perhaps you didn't have not see much value in computer modeling. Then I found the Aero Channel and discovered I was badly mistaken. Whoops. I've been reading the posts in the Aero Channel. It's great, It answers a lot of things I wondered about. I may even have a few questions of my own eventually. Thanks for creating that.
BTW, nice gliders.
Actually, U, I do see the value of computer modelling
but I take the results with a very large pinch of salt as they often do not carry forward to real, actual, in-the-air flying. In looking at model glider designs, too many people make two big mistakes:
1. Some think that computer simulations actually apply, verbatim, as is in real flight. OK, If so why do our aviation companies and educational facilities still need expensive, noisy wind tunnels?
2. Many people think that the Aerofoil section is the BIG DEAL, the B-All and End-All for deciding the performance of a model aircraft. Well it aint, in fact is a relatively small part of a big collection of stuff.
This is why any designer worth his salt should be able to stand by his design and answer any, and all questions as to the design points and why they were used - including the aerofoils.
I guess all this aerofoil aerofoil, aerofoil, discussion by the armchair aerodynamicists is because aerofoil plotters are readly available, and a little knowledge can turn out to be a bad thing. At our toy aeroplane sizes, I can tell you from hours and hours of actual testing - in wind tunnels - that very little full-sized knowledge is useful, or even applicable.
This 'scale effect' should also be common sense because as general rule if you want to test even the most basic aerodynamic performance of a full sized aircraft then (Unless you work at NASA Ames) your model has to be at least 33% of the actual size. In fact we modelllers are talking about tiny aerofoils performing a very low Reynolds numbers and where the boundary layer departure begins at only 40 to 45% of the chord.
This fact in itself makes a travesty of all this wise "hot air" aerofoil analysis.
Its a fact that a
NIKE Size 12 (mod) or
Converse size 13-mod aerofoil would work just as well as any vaunted 'super' section as long as the curves were in the right places and the front end was rounded and the back sharpened up.
So for our models, if the aerofoil is modern (Though a lot of the oldies are REALLY good too), and the model is well designed to do its job, then there will be a large variety of sections available, and in actual flight the difference between them will be very little.
I can also tell you that despite disparagement, the old adage "If it looks right, it flies right" really is true.
Glad you like the models!
