Nigel
Moderator
When the last shipment of Mini-Q's arrived, I quickly decided that I wanted to pick one up for myself, as I've never had a full-glass ship before, and figured the Mini Q would be a good first glass airframe.
After looking at a couple quad motors, I quickly became interested in our newer Typhoon Series. A couple of minutes on e-Calc landed me with an interesting setup. A Typhoon EDF 5W 1800KV on 6s produced 28 amps on a 4.5 x 5.5 APC. I decided to use a 40 Amp Nueron S ESC to monitor all kinds of useful telemetry, like current, battery voltage, and temperature.
All but 3 of the components above would eventually be replaced.
The largest hurdle in this build turned out to be the battery. I planned on using a Tattu R-line 1050 MaH 6s, however as you can see things ended up heading downhill quickly. I tried trimming the recess, which was already required as the canopy hold-down interfered, however the battery was still too large.
I then decided to try Butterflying the pack, essentially turning one battery into two connected by an octopus of wiring.
No, I did not leave all the terminals exposed
While the battery did fit, it was a nightmare to pull in and out. Doing so also necessitated the removal of part of the wooden bulkhead, something I was understandably unhappy about. After I removed the bulkhead and felt the wing flex, I came to my senses and scrapped the 1050. I can fit a 4s 1300, as well as a 6s 650 into the front fuselage, which should suffice.
