Now available in store:
Gentle Lady Evo Kit
Build and fly the Gentle Lady Evo Kit, a 55in / 1400mm RC sailplane with AG airfoils, quick-build wood construction, and an electric glider option.
alofthobbies.com
Gentle Lady Evo Kit
I don't know what happened, but this started off as a really simple design. I was going to keep it quiet until the prototype flew, but it sort of spun out of control and I thought I'd share and see what you all think.
This started off as a 55" Gentle Lady Evo kit. That was the plan. To me the "EVO" name means I can improve the design the ways I think would be best. I'm not locked into the original other than basic style. So more and more I thought, what would the designers of the Gentle Lady have done if they were tasked with the kit using our current tooling methods. This started as I debated the double spars in the wing, and the oddball sheeting used in the Gentle Lady. I saw no need for those items in this smaller size, so away they went, away went the old airfoil, away with the dihedral angles, and you get the idea. Then I decided I really don't like the center rubber bands, why not make it a plugin wing.. Is it still a gentle Lady if I do that? In the end I said yes, this is an EVO after all. And evolution of the design. So in came half ribs to maintain the far better blended AG airfoils. I don't love the extra weight, so lets add some lightening holes, now lets add some arcs to the leading and trailing edges.
Before you know it it starts to look something like this:
We are about 56" wing span. The fuselage is pretty close in shape to the original, but with a bit of pressure recover on the tail moment and parallel sides at the wing with a subtle bubble out in the nose. When rounded out she will look very little like a Gentle Lady, but you can leave it squared off if you like for more of a GL look. The tail areas are smaller, but currently holding similar shape. They will be built up structures also.
The goal is to have a plane that flies great and looks great when covered in translucent film.
Is this what the designers of the original GL would have done today? Probably not. I did not focus on her being a trainer, but more of a plane everyone will want to fly. I have kept her easy to build even though the wing looks complex, it will go together very fast. Same with the fuselage.
What do you think?
