Beezerdbd34
I have a 5.3m glider with 4 flaps and 2 ailerons. Everything is set up okay but I would like to have the ability to either use Inner or Outer Flaps to Ailerons or both flaps to ailerons. Obviously controlled via switches. I seem to have a bit of a mental block on how to program this, maybe I am being a bit ambitious. I use a Tandem x20s tx. By way of example, an advantage I see is that if I link, say, just the outer flaps to the ailerons the inner wing will continue to work at optimum efficiently, but if I want to rip up the sky for aerobatics, I might want to link all flaps to the ailerons.
