Dana Hager
I just read an older post from Wayne and liked his comments with respect to Hotliners so I figured I would give it an appropriate title. I will break up the build log as it is rather lengthy.
I decided to build a 3DLabPrint Joker over the winter months. The first print went well using the recommended settings from 3DLabPrint and Simplify3D on my Prusa i3 MK3S printer.
Components
EMAX GT2215 GT2215/09 1180kv Motor
Turnigy Plush 30A ESC
Turnigy Nano-Tech 3S 65C-130C 1800mah Lipo battery
Turnigy Nano-Tech 200mm Battery Strap
Frsky GRX8 Vario receiver
(2) HTX900 Micro Servo, 9g
(4) Corona DS-239MG Slim Wing Servo, 22g
(2) 15cm servo extensions
(2) 45cm servo extensions
Aeronaut Cam 10"X6" (25.5x15 cm) blades
Aloft Hobbies Turbo Folding Prop Spinner, 36mm
Aloft Hobbies Turbo Folding Prop Spinner Collet, 4mm
MP Jet Plastic Clevises, M2
2mm all threaded rod
K&S Metals 0.039” (1mm) music wire (push rods)
Dubro #511 antenna tubing (0.074" ID 0.134" OD push rod housing)
Carbon fiber tubing - 6mm OD x 4mm ID x 360mm long, 6mm OD x 4mm ID x 640mm long
Miscellaneous hardware as called out in the 3DLabPrint manual
Fillamentum PLA Crystal Clear Iceland Blue, 1.75mm
Fillamentum PLA Crystal Clear Amethyst Purple, 1.75mm
colorFabb PLA/PHA Orange Translucent, 1.75.mm
Hatchbox PLA True Black, 1.75mm filament.
BSI Insta-Cure+ Medium CA, BSI Insta-Set Accelerator
Print Times and Weights
Fuselage
colorFabb PLA/PHA Orange Translucent 1.75mm filament.
Default 3DLabPrint processes in Simplify3D.
Print time (hrs:mins) 17:00
Part Description - Factory / Actual
Fuselage part 1 - 32g / 35.15g
Fuselage part 2 - 42g / 44.90g
Fuselage part 3 - 23g / 25.21g
Fuselage part 4 - 25g / 26.26g
Fuselage part 5 - 17g / 17.31g
Fuselage part 6 - 19g / 20.08g
T Weight - 158g / 168.91g
V-Tail
Print time (hrs:mins) 04:13
V-Tail part 1 Left - 11g / 11.86g
V-Tail part 1 Right - 11g / 11.86g
V-Tail part 2 Left - 8g / 7.86g
V-Tail part 2 Right - 8g / 7.83g
Total Weight -38g / 39.41g
Elevons
Fillamentum PLA Crystal Clear Amethyst Purple , 1.75mm filament.
Print time (hrs:mins) 2:08
Elevon Part 3 Left - 4g / 4.30g
Elevon Part 3 Right - 4g / 4.18g
Elevon Part 4 Left - 4g / 4.30g
Elevon Part 4 Right - 4g / 4.21g
Total Weight - 16g / 16.99g
Servo Holder
Print time (hrs:mins) 01:10
Servo Holder - 8g / 8.37g
Central Wing Clip - 2g / 2.17g
Total Weight - 10g / 10.54g
Wing Center Section
Fillamentum PLA Crystal Clear Iceland Blue, 1.75mm filament.
Print time (hrs:mins) 16:06
Part Description Factory / Actual
Wing Part 1 Right - 79g / 84.91g
Wing Part 1 Left - 79g / 84.86g
Wing Outer Sections
Print time (hrs:mins) 18:38
Wing Part 2 Right - 41g / 44.55g
Wing Part 2 Left - 41g / 44.59g
Wing Part 3 Right - 35g / 38.95g
Wing Part 3 Left - 35g / 38.90g
Total Weight - 152g / 166.99g
Wing Tips Sections
Print time (hrs:mins) 11:55
Wing Part 4 Right - 28g / 30.13g
Wing Part 4 Left - 28g / 30.14g
Wing Part 5 Right - 22g / 24.43g
Wing Part 5 Left - 22g / 24.44g
Total Weight - 100g / 109.14g
Servo Covers
Print time (hrs:mins) 00:54
Wing Part 1 Right - 5.5g / 7.11g
Wing Part 1 Left - 5.5g / 7.11g
Total Weight - 11g / 14.22g
Flaps
Print time (hrs:mins) 04:27
Flap Part 1 Right - 5g / 5.87g
Flap Part 1 Left - 5g / 5.91g
Flap Part 2 Right - 7g / 7.62g
Flap Part 2 Left - 7g / 7.58g
Flap Part 3 Right - 7g / 7.47g
Flap Part 3 Left - 7g / 7.49g
Total Weight - 38g / 41.94g
Ailerons
Fillamentum PLA Crystal Clear Amethyst Purple , 1.75mm filament,
Aileron Part 1 Right - 6g / 5.91g
Aileron Part 1 Left - 6g / 5.87g
Aileron Part 2 Right - 8g / 9.05g
Aileron Part 2 Left - 8g / 9.01g
Aileron Part 3 Right - 8g / 8.93g
Aileron Part 3 Left - 8g / 8.85g
Total Weight - 44g / 47.62g
Canopy
Canopy Part 1 Front - 6g / 7.72g
Canopy Part 2 Back - 9g / 10.67g
Total Weight - 15g / 18.39g
All parts printed and assembly complete. Minimal cleaning was required using the 3DLabPrint profiles in simplify3D. A X-Acto knife and small needle files were all that was required to remove the brims and minimal supports. Parts fit is excellent and should provide strong glue joints and clean seams.
A word of caution, one should not use wire cutters or scissors to remove the brims or other supports in thin wall printed parts!
The shock will cause the layers to split and crack the delicate structure. Scoring with a knife and gentle flexing is all the is required.
Components
Fuselage
V-Tail
Elevons
Servo Holder
Wing Center Section
Wing Outer Sections
Wing Tips Sections
Servo Covers
Flaps
Ailerons
Canopy
